Partage : 5
où trouver un switch bypass pour SUMMIT DCL 200
le Dim 25 Sep 2011, 17:55
Je cherche où acheter sur Paris, ou un magasin online, un switch bypass de Summit DCL-200...le ressort d'un des deux a rendu l'âme ( il reste en position IN heureusement Very Happy )
Et autre question par rapport à cette machine : je voudrais changer les 3 lampes, et ne connaissant pas grand chose à l'intérieur des machines, je me demandais si il y en avait des mieux que d'autres, avec différentes couleurs, etc...???
Merci de votre aide, et de vos réponses
et merci à ce forum, sur lequel je viens très très régulièrement choper des avis très précieux avant de me lancer dans l'achat d'une machine...
Fab
Re: où trouver un switch bypass pour SUMMIT DCL 200
le Dim 25 Sep 2011, 19:23
pour le switch surement ici
quant aux lampes on peut en parler mais médites déjà ceci:
The tubes that are used in the DCL-200 are selected to give the best possible performance in the position that they are in on the printed circuit board. Switching them to different positions will cause performance deterioration on the audio path. Replacing them with “gold” or high end tube types may not be desirable. In cases that we have measured, these tubes have shown higher distortion and noise as compared to the tubes we have selected. In some cases, the so called “gold” or high end tubes have made the unit unusable. The reason for this is some of the “gold type” tubes are selected for high distortion in guitar amplifiers. Using gold tubes is no guarantee of better performance. All of these so called “Brand X” types are selected with 6.3 volts AC on the heaters, whereas Summit Audio uses 5 volts DC on the heaters for longer tube life and lower noise. The reduced gain can raise the noise floor, increase distortion, and reduce headroom.
For proper performance from a tube, the replacements must be selected using 5 volts DC on the filaments. The tubes we use are selected in the circuits that they are used in to ensure proper operation, long life, and low distortion and noise.
In at least 50% of the cases we have tested, gear that has been used for several years actually have lower noise and distortion levels than when new. This makes the question of when to replace tubes difficult to answer. If a tube turns micro-phonic, the distortion will be obvious and the tube must be replaced. However, tube life will most likely be greater than 10,000 hours of operation. Tubes are generally very reliable; don’t replace them just because they are old. In the DCL-200 there are gain adjustments that will need to be checked when the tubes are replaced, or else the metering could become inaccurate and the noise floor could change. Replacement should be done on the bench with a distortion analyzer attached to ensure that the distortion levels are proper and it is comprised of second order harmonics.
Before replacing the tubes in your DCL-200, please talk to your dealer, call Summit Audio, or find a technician who has experience working with tubes and high end audio equipment.
le Dim 25 Sep 2011, 23:23
RAM Audio ou Selectronic, près de Nation.
http://www.vdram.com/
Merci John pour l'article
Partage : 5
le Lun 26 Sep 2011, 01:00
Merci pour vos réponses rapides ! cheers
et en effet pour les lampes, je crois que tout est dit dans l'article, je vais m'en tenir a celles indiquées par Summit...
Partage : 272
le Lun 26 Sep 2011, 11:26
Oui l’article résume tout,
changer des lampes a l'aveuglette dans un appareil , sans prendre en compte les designs et choix du fabricant a l'origine de ce circuit particulier, peut être pire que bien !!!
et souvent en plus il ne s'agit pas de juste replugger une lampe sur son support, il se peut ( et c’est le cas ici) qu'il y' ait des point de polarisation a retoucher !!!
Merci Papa de nous maintenir "Aware" comme dirait l'autre !!
