aurel45
Partage : 186
Mic Stand Mount for the original iPad
le Mer 06 Avr 2011, 16:43
bien pratique pour nous les ingénieux ( stagemix, ilive tweak , presonus )
Whether for recording lyrics, displaying sheet music, tabs, or whatever, your iPad may be the most useful thing to hit the studio since gaffer tape.
Griffin's Mic Stand Mount for iPad screws onto a standard microphone stand (5/8" with 27 threads/inch for those of you playing along at home) so you can raise or lower your iPad to the perfect height. It also slips into most standard mic clips.
Rubber-lined grips at the ends of the Mic Stand Mount's four arms hold your iPad securely on all four corners without blocking the controls, dock connector or audio jack. The mount rotates and locks into either portrait or landscape view, and tilts up to 90 degrees. The grips accommodate most shell- and skin-type cases for iPad.
The Mic Stand Mount for iPad: the most secure way to mount your iPad in the studio (at least until your entourage grows to include "Dude Who Holds My iPad Like a Music Stand").
Features
- Mount your iPad on a mic stand
- Screws onto industry standard (5/8" 27-thread-per-inch) microphone stands
- Fully adjustable tilt and swivel; locks safely and positively into landscape or portrait orientation
- Rubber inserts securely grip your iPad on its four corners
- Full access to volume controls, dock connector, and audio jack
NOTE: Just as you would with an expensive mic or other equipment, make sure your mic stand and boom are properly counterweighted, tightened and positioned to support the weight of your iPad. If using Mic Stand Mount on a boom, we recommend aligning the boom with one of the legs of your stand to provide an extra element of stability. And mind your windmills.
site
Prix 39$99
http://web.me.com/aurel.sondier
Re: Mic Stand Mount for the original iPad
le Mer 06 Avr 2011, 20:19
yess encore un truc de geek !! Smile
dd64
Partage : 138
le Mer 06 Avr 2011, 21:37
C'est pas hyper beau mais ça doit être bien pratique dans certains cas...
