Digital audio Denmark, du très haut de gamme! Empty Digital audio Denmark, du très haut de gamme!
le Mar 04 Aoû 2009, 19:33
Digital audio Denmark, du très haut de gamme! Image_20
The AX24 Converter System is Musical,
Correct, and Flexible. AX24 allows you to config the number of line and
Mic channels that you need at the sample rate currently used. Analog in
and output channels can be expanded in pairs of two. Especially
configurations like 2 or 4 analog input channels and 6 analog output
channels are very suitable for mastering or multi track productions
where only few analog input channels are used simultaneously but
monitoring in 5.1. is essential.
24 bit PCM sample rates up to 384 kHz, DXD and DSD.
AX24 is based on the Digital Audio Denmark high quality multi bit
converter and modulator design, using a 5 bit delta sigma modulator.
AX24 offers A/D and D/A conversion in PCM up-tp 384 kHz, DSD at 64fs or
128fs and DXD at a sample-rate of 352.8 kHz. AX24 covers applications
for music recording as well as mastering and monitoring in DSD.
Mic pre with analog gain
in 3 dB steps and digital gain with 0.25 dB accuracy is available for
AX24 providing a sonically very transparent integrated Mic pre and ADC
design. The Dynamic range is between 118 & 121 dB and the Mic pre
equivalent noise floor is at -130 dB. AX24 offers an impressive dynamic
range , making it the quietest and most transparent converter on the
market.
Full remote controllable via USB or Ethernet.
AX24 is ideally suited for stage box applications or machine room
environment, due to the powerfull remote control. The remote control
interface is RS-422 nad can be adapted to USB, Ethernet or other data
formats providing a very flexible control structure.
The DADman control utilities,
provides various control interfaces for MAC and PC. This enables the
Mic pre controls can be represented on the channel strip of major
consoles, and various DAW including ProTools HD
Modular Interface structure.
All DAD-I/O modules are available for AX24 providing interfacing for
the most used PCM formats up-to 96 kHz. Additionally the 8 channel AES3
module can interface 192 kHz and 384 kHz on a multiple wire interface.
The MADI interface,
supports all the sampling formats of the AX24, and is an extremely
powerfull and capable interfaceMADIwhich input and output all the PCM
rates up-to 192 kHz as well as DSD and DXD. The interface can be
configured to operate in a daisy chain for connecting more converters
to the same MADI link. The MADI interface and the converter can be set
to access any of the up-to 64 MADI channels in any confuration in
blocks of 8 consequetive channels. All "unused" channels are linked
trough the interface with very low latency of only a few samples.
External synchronisation
to AES 11, Word Clock, Super clock or video (PAL, NTSC, SECAM) . The
built-in PLL circuit is able to correct for minor variations in the
external sync clock signal, giving a very stable adaptation to the
external synchronisation signal.
Sync alarm. If a
digital output is chosen with the DA source button, and the digital
input for some reason is out of synchronisation, the red Sync alarm LED
will blink. This function is available to secure that the whole
recording system is synchronised. The function can be turned off in the
system menu.
Features:
  • Fully Modular - 224 different configurations
  • Sample rates and I/O structure can be upgraded
  • From 2 to 8 analog Line or Mic input channels
  • From 2 to 8 analog output channels
  • 24 bit PCM sample rates up to 384 kHz
  • DXD sample-rate: 352.8 kHz
  • DSD sample rates: 64fs & 128 fs
  • Digital I/O: MADI, AES3, S/PDIF, TDIF, and ProTools
  • Digital DSD formats compatible with MADI and SDIF-3
  • Integrated Mic pre with analog gain
  • Full remote controllable via RS-422, USB or Ethernet
  • Mic pre controls can be represented on the channel strip of major consoles and work stations
Digital audio Denmark, du très haut de gamme! Empty Re: Digital audio Denmark, du très haut de gamme!
le Mar 04 Aoû 2009, 20:53
Joli un peu lourde dans mon sac mais en fixe ,a etudier
